1993 Ford Aerostar leaking
168,555 MILES • 6 CYL • 2WD • AUTOMATIC
BJC25MOTO
my trans leaks fluid out of the bell housing. it started all at once i think. i mean it was leaking fluid from some were but could never really tell were. and now it leaks a lot but only when driven, not when parked. if i drive it spues fluid. what mite the fluid be coming from inside the bell housing??????
Jun 9, 2008 at 5:45 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:b9ed2d0868="bjc25moto"]Transmission problem
1993 Ford Aerostar 6 cyl Two Wheel Drive Automatic 168555 miles
my trans leaks fluid out of the bell housing. it started all at once i think. i mean it was leaking fluid from some were but could never really tell were. and now it leaks a lot but only when driven, not when parked. if i drive it spues fluid. what mite the fluid be coming from inside the bell housing??????[/quote:b9ed2d0868]
Well what fluid are you having to constantly fill? If it is oil then you probably have a leaking rear main seal. If it is tranny then you most likely have a leaking front pump seal. If it is coolant then possibly a freeze plug....
Jun 14, 2008 at 8:05 AM
