1993 Ford Aerostar Horn doesn't work.
1993 FORD AEROSTAR
92,000 MILES • 6 CYL • 2WD • AUTOMATIC
PENGFEI
I have 1993 Ford Aerostar. I just found the horn did not work so I checked the fuse and I found the fuse was blown. I replaced it but once I try sounding the horn, the fuse was immediately blown again. What else can I do to check/solve the problem? Thanks!
Jan 27, 2008 at 10:21 AM
BLACKOP555
  • 10,386 POSTS
check for a short in the horn or one of the horn power wires, and its relay.
Jan 27, 2008 at 10:54 AM
PENGFEI
[quote:7f72b56323="blackop555"]check for a short in the horn or one of the horn power wires, and its relay.[/quote:7f72b56323]
Could you tell me more how to check for a short?
Jan 27, 2008 at 1:14 PM
BLACKOP555
  • 10,386 POSTS
with specific equipment. or check for voltage at wire at relay. and at horn. if they are the same theres no short, id rather rewire it.
Jan 27, 2008 at 11:24 PM
