1993 Ford Aerostar fuel problem
175,000 MILES • 6 CYL • FWD • AUTOMATIC
ALLINDABO
i left the car idling for like 2 minutes today and when i came back the car was choked down i restarted it and got like 20 ft and it cut off again. we tried to restart it and couldnt get it started and added gas and it didnt work so what could be the problems
Feb 13, 2009 at 12:20 PM
  • 75,988 POSTS
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Feb 13, 2009 at 12:26 PM
