1993 Ford Aerostar Engine Sputtering
127,000 MILES • 6 CYL • 2WD • AUTOMATIC
OREGONIANMILLER
My engine sputters like it is only running on two or three cylinders. Trouble making it up hills and with lots of weight. Anybody have an idea?
Sep 5, 2010 at 12:49 PM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Sep 5, 2010 at 1:34 PM
