1993 Ford Aerostar engine runs only in neutral and park
144,231 MILES • 6 CYL • 2WD • AUTOMATIC
PEARL99
my engine died yesterday en route to work. the car has had no trouble or repair in ages. it died when i came to a stop at a red light. it started right back up easily, but died as i shifted into drive. a coworker drove up and pushed me the last two blocks to work, where it now is resting. it starts easily and as many times as you twist the key to start it, but dies within a second of being shifted into reverse or any forward gear. what are the main possible causes (listed in order of probability if possible?)
Jun 19, 2008 at 7:45 AM
MMERLINN
  • 7 POSTS
Bad transmission is the most likely cause since the motor only stops when you engage the transmission.
Jun 30, 2012 at 10:51 PM
CARADIODOC
  • 34,413 POSTS
Try holding the gas pedal down 1/4" when you shift into gear. If it stays running, suspect the idle speed solenoid. Another clue is you will not get the normal "idle flare-up" to 1500 rpm when you start the engine if that solenoid isn't working.
Jul 1, 2012 at 12:02 AM
