Door lights are on even though doors are closed and engine off.
Nov 21, 2008 at 11:42 AM
✓Experienced Mechanic
Hi:
One of the door switches must have gone bad and keeping a closed circuit. You will need to remove them one at a time to check whiich one is the problem. You can test continuity to see which one isn't working.
