1993 Ford Aerostar Dome light poblems
1993 FORD AEROSTAR
115,000 MILES • 6 CYL • AWD • AUTOMATIC
BSSBB128
When I shut the door the dome light stays on. I had the same problem with my 1996 Ford Ranger. Is there a sensor in the door that tells the light when to shut off?
Jan 16, 2010 at 12:06 PM
MATHIASO
  • 1,209 POSTS
A short to ground in the circuit before the door switch would complete the circuit ,making the lights stay on regardless of the switch position.
To narrow the problem down,as no fuse is blown,the short is on the ground side of one of the switches.
remove each switch at each door and(check) trace the ground wire for short.
Jan 16, 2010 at 4:55 PM
BSSBB128
Thank You. I'll give it a try.
Jan 17, 2010 at 2:03 AM
MATHIASO
  • 1,209 POSTS
Thank you for your donation and for visiting 2CarPros.com
we hope to help you again the next time you need us
Jan 17, 2010 at 5:50 AM
