1993 Ford Aerostar died while driving
DWAYNE FISHER
Engine Performance problem
1993 Ford Aerostar 6 cyl Two Wheel Drive
driving down the road vehicle just quit and would not start....what procedure or procedures do i need to follow to test certain components so i dont have to start replacing parts unnecessarily
Feb 21, 2010 at 4:17 AM
  • 75,988 POSTS
Do below to determine whether it's fuel or spark problem.
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Feb 22, 2010 at 8:28 PM
