1993 Ford Aerostar Dash lights wiring
1993 FORD AEROSTAR
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
RUA
93' Aerostar, 3.0 V6 180K miles
Dash lights and Radio lighting goes out when Headlights are turned on. Also intermittent tail lights working.
Replaced Dash Cluster On/off switch. Replaced wiring block that attaches to switch. Brown wire from harness is a bit frazzled and wiring block melted around Brown connector. Lights may return briefly with a bump in the road but then go out again. Any suggestions?
Thanks
Aug 15, 2008 at 4:10 PM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Hi Rua,
Seems like a connection or contact problem.
The melted connector terminal might not be providing enough contact, clean and tighten to see if it helps.
Has headlight switch and relay been checked?
Aug 16, 2008 at 11:21 PM
