1993 Ford Aerostar CRUISE CONTROL
16,300 MILES • 6 CYL • FWD • AUTOMATIC
ROBERT VERMILLION
CRUISE CONTROL DOESN,T WORK AT ALL. ALSO THE HORN DOESN'T WORK. I DON'T KNOW IF THESE PROBLEMS HAPPENED AT THE SAME TIME.
Jun 7, 2009 at 1:35 AM
KHLOW2008
  • 41,812 POSTS
Hi ROBERT VERMILLION, Thank you for the donbation. Both problems could be related and might be caused by a faulty clock spring under the steering wheel. If vehicle is equipped with Airbag, there is a possibility the indicator would show an error if the circuits are broken as well. Does the cruise control light shows when main switch is turned ON? Check the horn relay circuit.
https://images.2carpros.com/forum/automotive_pictures/192750_HornRelay93Aerostar_1.jpg
Jun 7, 2009 at 2:40 AM
