1993 Ford Aerostar coolant smell in cab
19,600 MILES • 6 CYL • 2WD • MANUAL
LOGJAMS
I'm getting that coolant smell in cab. I'm assuming it is a heater core. I can't afford to have it fixed in the shop. I'm pretty good with tools and have changed cores before but this one must be tucked in pretty tight behind the glove box. Can you help me with info I need to replace it. I need my van for business...also I LOVE MY AEROSTAR !
Apr 23, 2009 at 4:32 PM
DAVE H
  • 13,383 POSTS
HEATER CORE
Removal & Installation
Drain cooling system. Disconnect heater hoses from heater core. Remove 6 plenum access cover screws. Remove access cover. Remove heater core from plenum assembly. To install, reverse removal procedure. Add coolant as required. Check for leaks.
Apr 23, 2009 at 8:36 PM
