1993 Ford Aerostar Car Won't Crank
148,000 MILES • 6 CYL • 4WD • AUTOMATIC
MSSASSYKRN
  • 6 POSTS
Recenctly purchased this care. Replaced starter, batter, and fuel filter. Car was cranking and was also driving yesterday. Today cold, rainy, snowy, car wont crank. What could be the problem? Amp light is now on also.
Mar 21, 2008 at 3:54 PM
FISHERMAN
  • 937 POSTS
[quote:994f7f7487="mssassykrn"]Engine Mechanical problem
1993 Ford Aerostar 6 cyl Four Wheel Drive Automatic 148000 miles
Recenctly purchased this care. Replaced starter, batter, and fuel filter. Car was cranking and was also driving yesterday. Today cold, rainy, snowy, car wont crank. What could be the problem? Amp light is now on also.[/quote:994f7f7487]
Hello !!
Well, we are going to start with the basics, check the battery cables, posts and connectors, be sure that are tight and clean, then turn the key and see if its trying to start or just dead (no sound or lights on the dashboard) let us know...
then try a "jumpstart" and tell us what happens,
why do you replaced the battery and starter?
it was acting like that before?
the battery was dead?
did you check the alternator?
let us know to continue with the troubleshooting.
BTW thanks a lot for your donation!!
we will be here waiting for your response.
Mar 21, 2008 at 4:13 PM
MSSASSYKRN
  • 6 POSTS
Hello !!
1. Done... Sound and lights working
2. Tried and still won't start
3. We were told that starter was a problem and just replaced battery because we had to jump it to start it and thought it needed a new one. Car had been sitting for 1 year without use just a montly crank up.
it was acting like that before? Yes but after starter was replaced the car ran fine all day yesterday.
the battery was dead? No
did you check the alternator? How?
Mar 21, 2008 at 4:30 PM
FISHERMAN
  • 937 POSTS
OK..
the shifter its in parking?
the shifter has a "switch" that prevents the car from start on a drive or reverse..
sometimes its out of sdjustment, "jiggle it" a little bit and try it again.
if still not cranking we are going to continue with the starter...
it could have a "loose' connection or wire..
did you replaced the starter by yourself?
did you know the location of it?
if so, check the connector from the battery (+) that goes to the starter and check that its tight also if you have a 12 volt light tester check the "signal" wire for power when cranking...
did you replaced the starter with a new one or reconditioned?
let me know to continue...
Mar 21, 2008 at 4:40 PM
FISHERMAN
  • 937 POSTS
Here you have an schematic of the starting wiring: The "S" its the signal wire (where you have to have "power" when cranking) also you can "jump" a positive wire from the battery to that terminal and if good the sterter should work which means that the problem its behind... .. if not the starter its faulty..
https://images.2carpros.com/forum/automotive_pictures/576_0_15.jpg
Mar 21, 2008 at 4:51 PM
MSSASSYKRN
  • 6 POSTS
Tried shifter no crank....and replaced starter with a new one.....used a alley mechanic :(, but it worked fine after starter installed on Thurs.
Mar 21, 2008 at 4:52 PM
FISHERMAN
  • 937 POSTS
[quote:99510e576f="mssassykrn"]Tried shifter no crank....and replaced starter with a new one.....used a alley mechanic :(, but it worked fine after starter installed on Thurs.[/quote:99510e576f]
could be a loose wire, bad starter relay or a faulty starter..
The starting circuit wiring its pretty simple... few wires involved..
any way, first, check the signal wire to see if we have power going to the starter (process of elimination) then.. will see...
Mar 21, 2008 at 4:58 PM
MSSASSYKRN
  • 6 POSTS
Had wires checked earlier.....
Mar 21, 2008 at 5:02 PM
MSSASSYKRN
  • 6 POSTS
Will check again in the morning and keep you posted. Thanks so much for helping me!
Mar 21, 2008 at 5:04 PM
FISHERMAN
  • 937 POSTS
No problem !!
we will be here.
good Luck!
Mar 21, 2008 at 5:07 PM
