1993 Ford Aerostar 6 cyl Two Wheel Drive Automatic
Hi i have a question i have a aerostar 3.0L with distributor, it and cranks but wont star, and doesnot have any spark, i cheked the distributor, ignition module, ign. coil, but nothing works, the only sensor i have left is the cam sensor but i cannot finded. would you tell me where is located?
i have notice something, the ign.coil,when have the electrical conection conected there in no readings (12 volts DC) but when i unpluge the electrical conector from tue ign.coil, there is a reding (12 VOLTS DC) YOUR HELP WILL BE GRATELY APPRECIATED THANKS. RUBEN.
May 4, 2009 at 12:41 PM
