CAR STARTS WHEN COLD AND CONTINUES TO RUN NORMALLY ON TRIPS. IF RESTART IS ATTEMPTED, EVEN BEFORE MOTOR IS WARM, IT WILL NOT START, REGARDLESS OF GAS PEDAL POSITION. I MUST NOT LET THE MOTOR STOP - FROM A TO B.
THE SAME HAPPENS EVEN IF HAS JUST BEEN STARTED SHORTLY BEFORE FROM A COLD START.
TO ME IT APPEARS THAT THE MIXTURE IS OVERVER RICH . I DO NOT UNDERSTAND WHAT HAPPENS DURING THE WARMUP CYCLE WHERE THE MOTOR RUNS FASTER DURING WARMUP - THEN IDLES DOWN. Perhaps an ADJUSTMENT CAN BE MADE TO CURE MY PROBLEM.
PRESENTLY - IF THE MOTOR STOPS ON A TRIP. I CANNOT RESTART AND MUST MUST PUSH THE CAR OFF THE STREET.
I MUST WAIT UNTIL THE MOTOR IS COLD - AND THEN - BE CAREFUL TO KEEP IT RUNNING ON THE FIRST START.
ANY HELP APPRECIATED,
EXLEY MIXON
EXLEY MIXON
Dec 19, 2008 at 11:48 PM
