1993 Ford Aerostar 1993 ford Aerostar starting problems
255,000 MILES • 6 CYL • 2WD • AUTOMATIC
KLEVIOUS
For the last month or so starting for the first time each day it had a weak start... now when i try to start it i get a clicking sound when tryng to start and the lights dim.
I replaced the battery and the celenoid but still all i get is the clicking sound when trying to start.
Im leaning toward the starter having gone bad.. is there anything else i can try or is that probably a safe bet??
Jan 20, 2010 at 6:36 AM
  • 110,248 POSTS
Have a helper turn the key to the start position while you check for voltage at the smaller wire at the starter. You should get 12+ volts.
Let me know what you find.
Jan 23, 2010 at 2:58 PM
KLEVIOUS
Thanks for the advice.. come to find out it was the starter... taping on it and it would start was a dead giveaway.
Cahnged it out and now startes like normal :)
Jan 24, 2010 at 11:21 AM
  • 110,248 POSTS
That is it. I'm glad you found the problem. You would have found that you were getting the voltage as described in my post which would have led me to tell you to replace the starter.
Take care and let us know if you have other questions, and thanks for using 2carpros.com.
Jan 24, 2010 at 1:59 PM
