HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Aerostar
Engine Cooling
Thermostat
1993 Ford Aerostar
EDWARK
MEMBER
1993 FORD AEROSTAR
6 CYL
2WD
AUTOMATIC
300,000 MILES
Van tends to overheat in hot weather. Would changing the thermostat help and where do I find it?
Wednesday, June 18th, 2008 AT 5:26 PM
OBXAUTOMEDIC
MECHANIC
Just follow the top radiator hose. It will take you right to it.
I would also check the fan clutch.
SPONSORED LINKS
Wednesday, June 18th, 2008 AT 10:59 PM
Please
login
or
register
to post a reply.
Related Thermostat Content
1993 Ford Aerostar Heating And Cooling
Thermostat Screws Won't Turn To Get The Thermostat Out
Asked by
ml863
1993
FORD AEROSTAR
VIDEO
Thermostat Replacement Ford
Instructional repair video
GUIDE
Thermostat
The thermostat is located on the engine either at the inlet or outlet radiator hose connections and is part of the cooling system, this unit is designed to stop the flow of...
1994 Ford Aerostar Heater And Thermostat Out
I Would Like To Know If The Thermostat Goes Out Would It Cause The Heater To Quit Working? They Both Decided To Quit Working At The Same...
Asked by
Robinc39
1 ANSWER
1994
FORD AEROSTAR
1992 Ford Aerostar Where Is The Thermostat On A 1992...
Where Is The Thermostat Located. How Do I Replace It. Thank You
Asked by
mrs hollywood
1 ANSWER
1992
FORD AEROSTAR
1993 Ford Aerostar Coolant Leak When Air Conditioner...
I Have A Major Coolant Leak That Only Seems To Happen If I Turn The Air Conditioner On, Even For A Minute. Why Would This Happen? If I...
Asked by
M H
1 ANSWER
1993
FORD AEROSTAR
1993 Ford Aerostar Water Pump
Engine Cooling Problem 1993 Ford Aerostar 6 Cyl Two Wheel Drive Automatic Is The Water Pump On A 93 And 95 The Same Wat Happens When...
Asked by
coons39
1 ANSWER
1993
FORD AEROSTAR
VIEW MORE
SPONSORED LINKS
Thermostat Replacement Kia
Thermostat Replacement Mercedes Benz C230
Online car repair manuals
