As far as the water problem, I was thinking about a bad gasket allowing water to get in your exhaust system.
Usually it is the headlite switch that activates the dash and tail-lamps. I'm not saying the switch is faulty, but if you looked at the wiring diagrams in your manual, if it has diagrams for the tail-lamps, you could track the circuit from that switch or backtrack from the tail-lamps. I don't have a wiring diagram for your tail-lamps. You might also look at the tail-lite bulbs and sockets. I have found some problems by wiggling the electrical connectors.
Sunday, January 18th, 2009 AT 10:29 AM
