1992 Ford Aerostar Where are the spark plug and how to reac
177,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHEMO87
Well i have a 1992 ford aerostar eddie bauer and i can't seem to get at the spark plugs they are too deep inside the hood and i cant reach them.
Mar 5, 2008 at 5:02 AM
DAMIEN FARMER
  • 10 POSTS
[quote:d4d5a1c3c3="Chemo87"]Engine Mechanical problem
1992 Ford Aerostar 6 cyl Two Wheel Drive Automatic 177000 miles
Well i have a 1992 ford aerostar eddie bauer and i can't seem to get at the spark plugs they are too deep inside the hood and i cant reach them.[/quote:d4d5a1c3c3]
I take the front tires off and change the plugs through the wheel well. I was a Ford guy for years and once you try this you might be tempted to change plugs more often. Don't forget to block vehical up for safty. Changing ignition wires is the same but must remove inside the vehical cover to reach either distribitor or coil pack.
Mar 5, 2008 at 5:59 AM
