1992 Ford Aerostar turn/hazard switch
76,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOHN BERGAN
location of switch
Sep 20, 2009 at 8:48 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the turn signal and hazard switches are used to operate these lights and are found on the steering column.
i'm assuming you mean the signal / hazard flasher relay which is located in the fuse block, under the left side of the dash.
Sep 22, 2009 at 1:19 PM
