1992 Ford Aerostar Sudden Brakeing
204,000 MILES • 6 CYL • 2WD • AUTOMATIC
KLT_LSH2009
When driving my van at 55 with the cruise set it will all of the sudden break and slow down. Afterwards i am unable to reset the cruise. When this happens it runs very rough and the gas petal feels very firm and hard to push. Since i got the van the oil pressure has seemed rather low. The word "normal" is across the gage and it has never went beyond the "r". The "nor" is on the side of "low".
Oct 19, 2009 at 11:06 PM
  • 110,244 POSTS
Has the check engine light ever come on?
Oct 20, 2009 at 2:04 AM
KLT_LSH2009
No it has bever came on.
Oct 20, 2009 at 4:59 AM
  • 110,244 POSTS
If there is no light, I need you to check for a couple things. First, make sure there are no vacuum leaks. Also, you need to check for fuel pressure.
Here is a how to for checking the pressure. Let me know what you find:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Oct 20, 2009 at 5:04 AM
KLT_LSH2009
I will check those things and get back to you. I have another question. Every now and then I notice a puddle of water under the van. What could this be a sign of?
Oct 20, 2009 at 5:33 AM
  • 110,244 POSTS
Could it be condensation (water) from AC usage or is it coolant?
Oct 20, 2009 at 5:46 AM
KLT_LSH2009
It looks like clear water. It doesn't do it all the time. I have never ran the AC. Can it still build up condensation? I know that it kicks ona nd of when running the heater. Could the sudden brakeing just be a faulty wire in the cruise control system?
Oct 21, 2009 at 11:13 PM
  • 110,244 POSTS
Chances are the condensation is coming from using the defroster. When it is used, the AC is run to help clear the windshield. If it is clear water and there is no coolant, I wouldn't be too concerned about it.
Oct 22, 2009 at 12:48 AM
