1992 Ford Aerostar replaced selenoid, but still have to bri
300,000 MILES • 6 CYL • 2WD • AUTOMATIC
RRHALL
when i turn the key to start the van, i get nothing but a few clicks under the hood, which i traced to some relays(or some thingys) mounted next to the selenoid, and have wire connectors/harness that click into them. i replaced the ignition switch, starter, selenoid, battery, and ignition cylinder. before replacing anything, i could start it by bridging the selenoid. i still have to bridge it to start, what else could be the problem?
Feb 7, 2009 at 9:58 AM
  • 110,248 POSTS
Hi:
really the only thing left is the starter relay or a broken wire to the starter. Have you checked to see if you are getting power to the relay?
Feb 8, 2009 at 5:04 AM
RRHALL
ive replaced the solenoid, but where is starter relay? the wires to starter are fine, and i just replaced ignition coil and still can only start by putting key in run and jumping the solenoid with screwdriver
Feb 15, 2009 at 11:40 AM
  • 110,248 POSTS
There should be a relay block under the hood.
Feb 16, 2009 at 12:45 AM
