1992 Ford Aerostar Major Water Loss
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
REDY4RAPTRE
Since the weather has warmed up my van loses water rapidly. I have to carry jugs with me to fill up after stopping. I can't tell where the water is leaking from since the engine is so tight. I had the radiator changed 1.5 years ago and some of the hoses associated with it. Can you help?
Apr 2, 2009 at 9:51 AM
  • 31,937 POSTS
HI there,
You will need to get a cooling system pressure test done, this will locate any external coolant leaks, you may have to have it up on a hoist to inspect the engine from below to view all the hoses.
Mark (mhpautos)
Apr 2, 2009 at 9:54 AM
