The heater fan seems to be dead. I can't locate it to replace. Can you tell me where to find it?
Sep 21, 2009 at 2:54 AM
✓Experienced Mechanic
The blower motor is located on right side of firewall -if you power up the motor direct from the battery and it turns on then its not the problem -could be a fuse , blower motor relay, resistor and blower motor control switch
Sep 21, 2009 at 5:16 AM
IRABIKE
MEMBER
Thanks, but still unsure of location. Can I get to it from inside the car on the passenger side or do I have to go in from under the hood?
