1992 Ford Aerostar headlights
1992 FORD AEROSTAR
20,500 MILES • 6 CYL • 2WD • AUTOMATIC
WAYNE ROEHRICH
after changing the headlight switch the headlights no longer come on.the parking light worked at first but has since stopped working.I read in a repair manual of a reostat located behind the fuse box.could this be related to the original problem.
Aug 25, 2010 at 12:58 AM
JDL
  • 16,098 POSTS
The yellow wire at the headlamp switch should be hot all the time, is it? If not, it gets voltage from fusible link. When you turn on the headlamp switch, the red wire with yellow tracer goes hot and sends voltage to the dimmer switch.
https://images.2carpros.com/forum/automotive_pictures/170934_aerostar_headlamp_switch_1.jpg
Aug 25, 2010 at 6:57 AM
