1992 Ford Aerostar fuel pump
100,000 MILES • 6 CYL • FWD • AUTOMATIC
BRAZZ5099
van hard to start-took the vehicle to the shop to install a new fuel pump drove for 1/2 day went home and the van will not start- what could be the problem
May 6, 2008 at 4:29 AM
  • 75,988 POSTS
Could be a fuel or spark problem do below to determine which.
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
Fuel pump and Injector/s checks out-start checking the ignition system-power to coil, coil/s itself,distributor pick-up,control module, Cam and Crankshaft sensors.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
May 6, 2008 at 4:35 AM
R.MATTHEWS
[quote:f0da9a0b7e="brazz5099"]Engine Mechanical problem
1992 Ford Aerostar 6 cyl Front Wheel Drive Automatic 100000 miles
van hard to start-took the vehicle to the shop to install a new fuel pump drove for 1/2 day went home and the van will not start- what could be the problem[/quote:f0da9a0b7e]
I had that same problem, I installed A new Fuel pump and that WAS_NOT the problem the problem was it was not firing, there is a metal ring inside the distributor, or the hub where all the spark plug wires are located. That ring was disfigured(chewed up) which caused the engine not to fire.
Jul 18, 2008 at 3:09 AM
