1992 Ford Aerostar fuel injectors
18,000 MILES • 6 CYL • 2WD • AUTOMATIC
JEFFAS
How do I test to see if my injector is bad, or if it's wiring.
Does someone have the ohme specs and the voltage specs from the wiring harness.
Is there a better way to test these things?
Mar 2, 2009 at 11:54 AM
  • 75,988 POSTS
15-18 ohms and battery voltage you can use a noid light
Mar 2, 2009 at 12:16 PM
