Electrical problem
1992 Ford Aerostar V6 Four Wheel Drive Automatic 243,00 miles
Hello
I first installed a new solenoid, and a new battery, as apparently, the battery drained completely dead; I cleaned the battery terminals and installed the battery and solenoid, near the firewall close to the battery.
I have a shop manual which shows a starter relay switch, which I have been unable to locate. I see two wire connectors, when tested showed power with the Voltmeter.
After reading the shop manual showing a starter relay switch (stating below and behind the battery), I am fairly confused at this point.
Do you think that the bendix spring in the starter could be stuck?
Or do you have any other help you may give?
Thanks
Hello
Thanks
Dec 7, 2007 at 10:36 AM
