1991 Ford Aerostar van starts idles rough,then cuts off
1991 FORD AEROSTAR
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
7JOKER4
I have a '91' ford aerostar sport with a 3.0 engine it was driving fine and all of a sudden it started idling funny and if I didnt keep the gas pedal pressed or if I hit the brakes it would stall out I have changed the spark plugs, spark plug wires ,distributar cap, roter button,Oc sensor, and the idle air control sensor but it still does the same thing I have also checked the fuel filter and fuel flow and they seem to be good I dont know what else to check if you have any ideas please let me know thanks.
Jul 17, 2010 at 5:35 AM
Clean out the idle air control valve and EGR valve, also test the throttle position sensor and also clean the MAF sensor with an approved cleaner
Jul 17, 2010 at 7:13 AM
