1991 Ford Aerostar OIL LEAK
STOWN45
Engine problem
1991 Ford Aerostar 6 cyl Two Wheel Drive 220000 miles
I HAVE AN OIL LEAK BETWEEN MY MOTOR AND TRANMISSION,BUT I CAN'T TELL IF IT'S COMING FROM THE REAR MAIN SEAL,OR THE REAR OIL PAN
GASKET.IS THERE ANYWAY TO TELL THE DIFFERENCE?
Jan 4, 2008 at 11:24 AM
BLACKOP555
  • 10,386 POSTS
mainly you should clean off all the oil with a rag then start the car and look to see where it is coming from, the oil could be coming from a differnent location and jjust leaking down there and collecting.
Jan 4, 2008 at 12:01 PM
