1991 Ford Aerostar how quarts does it take to fill
IRMA BUSTAMANTE
  • 1991 FORD AEROSTAR
  • 6 CYL
  • 105,850 MILES
Once transmission oil is drained how many quarts will I need to replace
Monday, June 14th, 2010 AT 5:37 AM
BMRFIXIT
  • 19,053 POSTS
FLUID CAPACITY
NOTE:Fluid capacities listed for A/T and M/T are approximate. Always determine correct fluid level by mark on dipstick and by gauging fluid level at fill hole (M/T) rather than by amount of fluid added.
AUTOMATIC TRANSMISSION REFILL CAPACITIES (1)
ApplicationCapacity
AOD Transmission12.3 qts. (11.6L)
A4LD Transmission
2WD9.7 qts. (9.2L)
4WD10 qts. (9.5L)
C-6 Transmission
2WD Models12.0 qts. (11.4L)
4WD Models13.5 qts. (12.7L)
E4OD Transmission
2WD Models15.5 qts. (16.4L)
4WD Models16.0 qts. (16.9L)
(1)Includes torque converter, cooler and lines.
Monday, June 14th, 2010 AT 5:51 AM
