1991 Ford Aerostar change the liftgate or the glass only
1991 FORD AEROSTAR
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
AEROFORDFIX123
Somebody broke the back window and I wonder if it's better to change the door because and pull your part it's cheaper and I don't know how to change only the glass any way it's expensive but the door it's difficult to install ? what it's the best deal please advice.
Oct 8, 2009 at 7:11 PM
  • 110,244 POSTS
If it is cheaper to get the entire door with the glass, I would go that way. The only problem is it will need painted to match unless you get lucky enough to find one that is the same color.
Oct 20, 2009 at 2:29 AM
