1990 Ford Aerostar wont start no spark
MARTINN1
Electrical problem
1990 Ford Aerostar 6 cyl Two Wheel Drive Automatic 100.00 miles
drove van,turn off van and now wont start
I replaced the coil, cap, and roter as well the coil wire
to the cap still no spark from coil and plugs you can smell gas
I did check the fule valve in the front of the engine
I pressed the air type valve in and gas squerted out
Jan 8, 2010 at 4:31 AM
BILLYMAC
  • 2,204 POSTS
Hi
This vehicle uses a tfi module located on the side of the dist or on the firewall. if this goes bad no spark
Jan 12, 2010 at 11:55 AM
