Howdy, I have a 1990 Ford Aerostar Cargo Van 277,000+/- miles. Engine will start, runs for between 45 seconds and 2 minutes then dies, originally checked fuel pressure at the fuel rail discovered it was low >20PSI, replaced fuel pump and strainer, fuel pressure improved 38-40PSI but problem persists. Pulled a plug to confirm spark, starts out bright blue fades to yellow and the engine dies. Suggestions as to probable cause greatly appreciated
Mar 7, 2007 at 7:02 AM
