1990 Ford Aerostar replacing tie-rods
BEENTHERE.DOLAN
Steering problem
1990 Ford Aerostar 6 cyl Two Wheel Drive Automatic
are there any special tools or instructions needed to change the tie-rod to steering rack?
I have to replace the steering rack as my aerostar will only turn left. I have two prices for the steering rack, on w/rods attached and the other separate. I am trying to determine time and cost vs convenience. I live in Hawaii where for me cost is a determining factor.
Thank you for your time and considerations[img:8a6e79e38d]http://www.2carpros.com/forum/automotive_pictures/564056_3460090061_02b6a88cbe_b_1.jpg[/img:8a6e79e38d]
Aug 21, 2010 at 12:48 PM
BLUELIGHTNIN6
  • 16,542 POSTS
the tie rod end is held on with a nut and cotter pin. remove that and it will disconnect from the steering knuckle. do you need replacement steps for the steering rack?
Aug 22, 2010 at 12:34 PM
