1990 Ford Aerostar Master Cylinder
ILUVMYTRUCK1965
1990 Ford Aerostar
I installed a master cylinder on a 1990 Ford Aerostar. The instructions said not to bench bleed as this can cause leaks. I bled it once it was installed on the vehicle using the bleed screw, but I am still getting air. What do I need to do?
Jun 21, 2009 at 6:24 AM
BLUELIGHTNIN6
  • 16,542 POSTS
clutch or brake master cylinder?
Jun 21, 2009 at 4:16 PM
ILUVMYTRUCK1965
[quote:0eb45dc034="bluelightnin6"]clutch or brake master cylinder?[/quote:0eb45dc034]
Brake
Jun 21, 2009 at 10:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Okay, if there is still air in the lines then you will just have to go over the process again. Below are the proper bleeding procedures for your vehicle's master cylinder..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_564.jpg
Jun 22, 2009 at 3:07 AM
