1990 Ford Aerostar Gas tank removal
130,256 MILES • 6 CYL • 2WD • AUTOMATIC
JUSZRH
i am havin a hard time removing the gas tank because the lil slip nut type things are breakin off an i can finish gettin the bolt out. i was wondering if yall had any suggestions on how to get those bolts out?? thank you..
Feb 18, 2008 at 2:33 PM
BLACKOP555
  • 10,386 POSTS
Usually i cut the tank straps off with bolt cutters, i then install new ones when i put the tank back up.
the straps are cheap and are usualy rusted and it saves alot of time.
Feb 18, 2008 at 11:19 PM
