1989 Ford Aerostar Engine died
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
TACOMA SOUNDER
The other day the van stopped running like it ran out of gas. (it hadn't) I added some gas just in case but it won't start. Now when you try to start it it spins really fast like there is no compression. I think I lost my timing chain. Can I just put a new one on or is it a zero tolerance engine and did I damage the valves etc..?
Aug 20, 2009 at 4:48 AM
  • 110,248 POSTS
I don't believe it is a 0 tolerance engine. Chances are if you replace the chain, it should be okay.
Sep 11, 2009 at 12:59 AM
