how do you remove a clutched cooling fan from the shaft ?
Jan 12, 2008 at 5:04 AM
BMRFIXIT
✓Experienced Mechanic
[quote:1b42e8ca39="jollyroger2005"]Other Category problem
1988 Ford Aerostar 6 cyl Two Wheel Drive Automatic 124,00 miles
how do you remove a clutched cooling fan from the shaft ?[/quote:1b42e8ca39]
Left turn hand nut fan clutch
Jan 12, 2008 at 5:43 AM
RMIESSLER
MEMBER
I ended up getting a special tool from the local parts store which has the wrench for the nut and another that holds the pulley.
