HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Aerostar
Engine Cooling
Cooling Fan
Replace/Remove
SPONSORED LINKS
1988 Ford Aerostar remove cooling fan
JOLLYROGER2005
MEMBER
1988 FORD AEROSTAR
6 CYL
2WD
AUTOMATIC
12,400 MILES
How do you remove a clutched cooling fan from the shaft?
Saturday, January 12th, 2008 AT 1:04 PM
BMRFIXIT
MECHANIC
Left turn hand nut fan clutch
SPONSORED LINKS
Saturday, January 12th, 2008 AT 1:43 PM
RMIESSLER
MEMBER
I ended up getting a special tool from the local parts store which has the wrench for the nut and another that holds the pulley.
Wednesday, January 16th, 2008 AT 12:06 AM
Please
login
or
register
to post a reply.
Related Cooling Fan Replace/Remove Content
1996 Ford Aerostar Clutch Fan Removal
Step By Step Directions To Remove Water Pump/ Fan On 1996 Ford Aerostar 3.0
Asked by
litljess77889
1 ANSWER
1996
FORD AEROSTAR
VIDEO
Radiator Cooling Fan Replacement Chevrolet
Instructional repair video
GUIDE
Radiator Fan Motor Replacement
A cooling fan helps move air through the radiator when the vehicle is stopped or moving slowly. An electric fan motor connected to a plastic fan blade located directly...
1992 Ford Aerostar Losing Water
I Need Help Tracking Down A Problem Where I'm Losing Water That's Coming Out Of The Top Of The Water Overflow Reservoir. When Parked, I...
Asked by
geeksatlarge
1992
FORD AEROSTAR
1997 Ford Aerostar Engine Loosing Water, No Viable...
I Am Loosing Water From Radiator, No Leaks At Engine. Have To Check It Every Day Or Two, Will Only Drive Very Limited With It. Wondering...
Asked by
wineo
1997
FORD AEROSTAR
1994 Ford Aerostar Coolant Leak
My 1994 Aerostar Sprays Coolant All Around The Side Of The Engine Compartment By The Heater Fan. No Coolant Smell In The Interior When...
Asked by
RickOhio
1 ANSWER
1994
FORD AEROSTAR
Leaking Coolant
Hello, I Am Hoping Someone Can Point Me In The Right Directions. I Have An 86 Ford Aerostar, 2.8l, 5 Speed, Mini Cargo Van That Seem...
Asked by
Taz_Man
1 ANSWER
FORD AEROSTAR
VIEW MORE
SPONSORED LINKS
Online car repair manuals
