1988 Ford Aerostar misting
MYMIND2001
Engine Mechanical problem
1988 Ford Aerostar 6 cyl Two Wheel Drive Automatic
i have replaced the plugs,plug wiring, control modual,map sensor, and it still running rich and i still have a mist. i have downloaded the firing order and everything is wear it supposed to be.. please helpm and give me some suggestions.
Apr 30, 2008 at 10:31 AM
MUSTANG87
  • 261 POSTS
you probably should have replaced the oxygen sensors instead of map sensor.and fuel filter .also those aerostars do better with autolite sparkplugs and cheap.
May 1, 2008 at 2:03 PM
