1988 Ford Aerostar fuel filter location
TRACTORBOY
Engine Performance problem
1988 Ford Aerostar 6 cyl Two Wheel Drive Manual
feul filter and pump?Where is it?1988 aerostar6cyl
Jun 10, 2008 at 11:27 AM
MUSTANG87
  • 261 POSTS
filter is in under the van possibly close to gas tank or somewhere on bttom sides just follow the fuel lines not sure what side but easy to find.fuel pump is inside the gas tank.must disconnect the battery cables to remove tank for safety,you dont wanna burn and die with gas fire explosion.even better remove gas from tank and it will be light to lower also.
Jun 10, 2008 at 2:53 PM
