Ok, your van ran hot and shut down. Well there are a couple reason this could happen.
Bad Thermostat
Bad Water Pump
Bad Radiator
Bad Fan Clutch
However, you missing an oil changed did NOT cause this problem Unless you ran out of Oil. If you ran out of oil you would have heared tapping then knocking noises coming from the engine.
SPONSORED LINKS
Thursday, June 3rd, 2010 AT 4:10 PM
