1987 Ford Aerostar
ELIO VELAZQUEZ
1987 Ford Aerostar 6 cyl Two Wheel Drive Automatic
when my veicle hits up i turn the motor off and when i want to turn on again it won't start.
Nov 22, 2009 at 1:44 PM
  • 75,988 POSTS
When it heats up and will not start-do below immediately
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Nov 22, 2009 at 1:59 PM
