1984 Ford Aerostar power windows &power locks
85,000 MILES • 6 CYL • 2WD • MANUAL
FRANK_TST
power lock button on drivers door will only unlock doors only, button on passengers door will lock &unlock doors. drivers power window does not work. how do i trouble shoot these problems.
Nov 30, 2008 at 12:35 AM
  • 110,248 POSTS
Hi:
First, it sounds like the switch for the locks is bad. As far as the window, it could be a switch or the motor. You need to remove the door panel and check for power to and from the window switch. Also, you need to check if you are getting power from the lock switch in both positions.
Dec 30, 2008 at 7:30 AM
