2004 Ford AA Motorcycle ?
2,400 MILES • 4 CYL • 2WD • MANUAL
BEURNARRD
My clutch makes a rattle and it's worn but whats specifily is the noise from?
Nov 4, 2010 at 7:13 AM
SATURNTECH9
  • 30,869 POSTS
Without taking it apart there is really no telling what the noise is it could even be inside the transmission.
Nov 4, 2010 at 7:32 AM
BEURNARRD
I had the trans done awhile ago totally, I just thought it might be somethimg I haven't heard Thanks
Nov 4, 2010 at 7:56 AM
SATURNTECH9
  • 30,869 POSTS
I would still make sure the input shaft bearing on the transmission didn't fail.I would most likely the throw out bearing probably failed and is making noise.But again if you have noise coming from the clutch then you really need to get in there to see whats going on.
Nov 5, 2010 at 5:46 AM
