Mustang 98 GT Low beam headligth problem
OSIELCR
I got a problem with my low beam, after use the low beam for 20 minutes it start to turn on and off by it self I have to turn the high beams on and turn the low beams off I got to wait like a minute the turn the low beams on again so it can let me drive the car with the low beams for five more minutes the in start to blink again.
Mustang GT 98
Nov 12, 2006 at 9:31 AM
CATCH_15
  • 250 POSTS
Try replacing the headlight bulbs. Sounds like they are going out.
Nov 12, 2006 at 3:05 PM
WEAREA2J2
  • 43 POSTS
Headlights are either good or bad. No in between. Like that pregnancy thing, you are or you aren't. It sounds like the low beam relay. Check in the harness or a tech. manual if you still have ?? Good luck!!
Nov 12, 2006 at 3:14 PM
