2007 Ford 500 Car jerking
2007 FORD FIVE HUNDRED
54,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANTHONYZACH
Hello, I have a 2007 Ford 500 SEL V6 2 wheel drive. I recently started having an issue when I turn the car on and when switching to drive car jerks it also happens when i'm at a stop and drive again or when I park it jerks. It seems it is getting a bit more worst today while driving there was a point where it did not want to accelerate then when stopping it wanted to keep jerking to where i stop and it kinda drag forward a bit. I had the codes check with nothing, transmission and engine fluids are good and also had the fuel filter replace. I have a feeling this might be Mass airflow censor or so.. Have any ideas? specially since after running a scan there are no codes return and no lights turn on the dash board.
Aug 14, 2010 at 1:23 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I would start with cleaning the throttle body, use a quality cleaner you can get it from any parts store, when this is done pleas advise any change and what the idle speed is.
mark (mhpautos)
Aug 14, 2010 at 4:32 PM
