Air conditioner issue
190,000 MILES
FIXITMR
  • 9,989 POSTS
so the other day i added a can of refrigerant to try and boost cold from air conditioner used it that day. next time i started it air conditioner did not come on neither indicator light on buttons air conditioner and recycle air works. i checked under-hood 10 amp air conditioner fuse okay and inside fuse for HVAC okay! also switched under-hood relay. now what? is there another fuse to check?
Aug 14, 2016 at 6:22 AM
SATURNTECH9
  • 30,869 POSTS
Have you tried wiggling around the blower speed switch ? I have seen those effect the lights on the buttons.
Aug 14, 2016 at 11:48 AM
FIXITMR
  • 9,989 POSTS
okay the lights are on when fan is on but still no cold so i guess i will have to start at compressor and trace backwards.
Aug 14, 2016 at 12:36 PM
SATURNTECH9
  • 30,869 POSTS
The gas you put in could have leaked out. What are the high and low pressures? Also you do not know how much was in before you added charge.Things we need to think about.
Aug 14, 2016 at 2:34 PM
FIXITMR
  • 9,989 POSTS
system has never leaked much over long time i did put a can in last year or year before. yes, i will take low pressure test to see what it reads if i get compressor to run.
Aug 14, 2016 at 2:42 PM
SATURNTECH9
  • 30,869 POSTS
We need pressures without the compressor running? Since the compressor does not turn on. air conditioners leak can change at anytime. I have had suction hoses off the compressor pop while I am charging the system. Scares me every time, lol. So leaks can get bigger at anytime.
Aug 14, 2016 at 2:49 PM
FIXITMR
  • 9,989 POSTS
oh, never have done a static pressure check. can try it.
Aug 14, 2016 at 3:17 PM
SATURNTECH9
  • 30,869 POSTS
Let's do that and see if there is enough pressure in the system to the compressor come on.
Aug 14, 2016 at 3:29 PM
FIXITMR
  • 9,989 POSTS
yes, my usual static test is poke valve with screwdriver.
Aug 14, 2016 at 3:44 PM
SATURNTECH9
  • 30,869 POSTS
Yeah, that only tells us it is not completely empty.
Aug 15, 2016 at 12:14 AM
FIXITMR
  • 9,989 POSTS
if i get a hiss i am confident it just needs Freon, no serious leaks.
Aug 15, 2016 at 1:11 AM
FIXITMR
  • 9,989 POSTS
i should have said if i get a weak hiss.
Aug 15, 2016 at 2:05 AM
SATURNTECH9
  • 30,869 POSTS
I cannot work that way people would be mad at me, lol.
Aug 15, 2016 at 2:13 AM
FIXITMR
  • 9,989 POSTS
when its your own vehicle your allowed to take shortcuts.
Aug 15, 2016 at 2:47 AM
FIXITMR
  • 9,989 POSTS
yah its prety much empty just a tiny hiss
Aug 15, 2016 at 5:13 AM
FIXITMR
  • 9,989 POSTS
somethin musta gave out proly a hose the main low pressure shows stains at joint with rubber
Aug 15, 2016 at 5:23 AM
SATURNTECH9
  • 30,869 POSTS
The hose that is right in front of the exhaust manifold gets roasted and they become brittle and leak/pop
Aug 15, 2016 at 5:33 AM
FIXITMR
  • 9,989 POSTS
it dont look brittle or hard maybe cuz im in a northern climate?
Aug 15, 2016 at 5:44 AM
FIXITMR
  • 9,989 POSTS
guess i'll try addin some again the stuff is pretty cheap
SATURNTECH9
  • 30,869 POSTS
Get some with AC dye in it but without stop leak in it.There's no shield on the exhaust manifold so all the heat radiates to that hose.
Aug 15, 2016 at 5:47 AM
SATURNTECH9
  • 30,869 POSTS
That hose is one of the most common places to leak.Also make sure the hoses on the AC compressor are tight.Especially the top hose that on can loosen up over time.
Aug 15, 2016 at 5:49 AM
FIXITMR
  • 9,989 POSTS
also pass rear window regulator is not working right motor works did it pop outa track or something?
FIXITMR
  • 9,989 POSTS
so anyway i added 2 cans of freon and it works again!! i mean it lasted like 6 hrs so far...will know more in morning.
Aug 15, 2016 at 3:28 PM
SATURNTECH9
  • 30,869 POSTS
Get a spray bottle and put some liquid soap in it then add water Spray all around everywhere including that hose by the exhaust manifold.Look for bubbles .Also for the rear window the plastic slider in the window regulator breaks.Saturn used to sell the sliders to fix the regulator..
Aug 15, 2016 at 10:51 PM
FIXITMR
  • 9,989 POSTS
worked this afternoon. yah i sprayed some windex on lowP hose and fittings when i added the freon didn't see anything but maybe windex is not the right stuff to use. it was handy at the time.
Aug 16, 2016 at 6:49 AM
SATURNTECH9
  • 30,869 POSTS
Soap and water with lots of soap
Aug 16, 2016 at 7:00 AM
FIXITMR
  • 9,989 POSTS
funny thing was when i went to poke high side port the valve needle wouldnt budge!?
Aug 16, 2016 at 12:23 PM
SATURNTECH9
  • 30,869 POSTS
No idea it's really safe to do that poking.They don't really freeze up from what I see.
Aug 16, 2016 at 12:45 PM
FIXITMR
  • 9,989 POSTS
still cooling/working
Aug 21, 2016 at 11:42 AM
FIXITMR
  • 9,989 POSTS
heres a strange 1. someone says they put way to much oil in a 2002 kia spectra and it was smoking bad. dont know how long they drove it that way. then they corrected the oil level and they say it still smokes too much. dont know how long they drove it after correction. they are selling it cheap. my thoughts are it may clear up with enough driving? i didnt see anything on net about kia oil burners.
Aug 21, 2016 at 11:47 AM
SATURNTECH9
  • 30,869 POSTS
Usually once you correct the over fill it will stop smoking after driving a while.
Aug 21, 2016 at 12:13 PM
