Foot brake failing every now and then
2007 SEAT IBIZA
65,000 MILES • 1.2L • 2WD • MANUAL
APHIPPY
Hi, i recently curbed my car and popped the front right wheel. since then I noticed my foot brake is not working properly. i had to swerve out the way of someone the other day and crashed into a wall lightly. does anyone know what this could be please?
Mar 6, 2018 at 4:37 AM
  • 55,224 POSTS
It sounds like you master cylinder has gone bad or you have a leak somewhere. This guide can help.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
and
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Mar 7, 2018 at 6:18 AM
APHIPPY
Ok cheers for the master cylinder to be gone or have a leak would it mean leaking break fluid as mine is still very full I have been driving the past 2 days and breaks haven't failed but they are stiff and quite noisy
Mar 9, 2018 at 3:53 PM
  • 55,224 POSTS
By noisy do you mean you can hear grinding?
Mar 10, 2018 at 3:03 AM
APHIPPY
Just like a low pitches squeek sort of puff of air to ya know? The more I press the brake in a row the harder it is to push down and then leave it for abit it lets the pressure go back down if ya get me
Mar 10, 2018 at 3:57 AM
  • 55,224 POSTS
It sounds like you have 2 problems first the brake booster is leaking causing the hissing sounds and the hard brake pedal next is the front or rear brake pads need to be replaced which is causing the grinding sounds.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
and
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
Cheers, Ken
Mar 12, 2018 at 4:05 AM
APHIPPY
Ok cheers gonna take it out to a garage at the end of the week see what they say
Mar 12, 2018 at 4:09 AM
  • 55,224 POSTS
Please let us know what happens so it will help others :)
Mar 12, 2018 at 4:19 AM
