Fog lights will not work light does not even come on in dash?
300,000 MILES • 6.7L • 4WD
CRAIGRAY1
Changed my instrument panel light and now my fog lights will not work light does not even come on in dash.
Sep 27, 2022 at 5:53 AM
  • 55,785 POSTS
Let's start by checking fuse #2, 20 amp in the under-hood fuse panel. Also recheck your work on the rear of the instrument cluster to make sure the wiring is connected correctly. Some clusters may not have the provisions for the fog lights so make sure you have the right part. Here is a guide to help you check the fuses and the fog light wiring diagrams so you can see how the system works:
Sep 28, 2022 at 9:01 AM
CRAIGRAY1
Thanks for the help. I found the problem was that the relay under the dash was unplugged.
Sep 28, 2022 at 12:53 PM
  • 55,785 POSTS
Yep, that will do it. Use 2CarPros anytime, we are here to help. Please tell a friend.
Sep 29, 2022 at 6:23 AM
